Old 04-14-2011
Dufour 27 Newb
jaybeegee is on a distinguished road
aluminium toe rail - how to scrape?
Hello all! As you can see from the attached link the aluminium toe tail of my Dufour 27 (1975) needs some work! I am considering scraping it off and give it abit of a polish rather than paint! Is there a recommended approach to ease scraping?
thanks,
J.
Old 04-14-2011
tommays's Avatar
It was most likely anodized which is not gonna scrape off with any kind of ease and painting it due to the amount of water it sees would IMHP become a nightmare
Taking it off and having a shop redo the anodizing would be the real cure
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 04-14-2011
paulk's Avatar
paulk is on a distinguished road
Painting aluminum is a nightmare. Primer gets on everything, and is a funky color. It has to be applied within X minutes (75?) of the surface being exposed to air. The finish coat has to be applied within Y minutes (!) of the primer being dry. The finish coat runs everywhere. Touching up what's there with some automotive spray paint (MASK CAREFULLY and EXTENSIVELY!) might be the simplest Quick & Dirty option. When it wears off, you slap on some more. It would probably be simpler to buy another boat with nicer-looking rails than to try removing the ones you have.
Old 04-14-2011
Pub911 is on a distinguished road
I had my alum' toe rail removed, sand-blasted and then powder coated - that's right, not anodized as it was originally, but powder coated in black (matching original). 8 years later and it looks like it was just refinished - EXCEPT for where it's taken a hard hit and the powder coating has chipped. But even in the damaged area, the chipping hasn't spread. That stuff is tough and stuck on good.
Good luck.
Old 04-14-2011
Good luck.
Would this job you did have cost less than buying new rail? or reanodizing the old?
On the one hand this kind of rail is probably getting a little hard to locate (though a member here recently did do just that).
I do agree with the others that a cosmetic coverup like painting is a non starter. Best to remove and retreat. The powder coating is an intriguing option, esp if it's not horrendously expensive.
1984 Fast/Nicholson 345
Old 04-15-2011
Dufour 27 Newb
thanks for taking the time to reply.
I will investigate the powder coating option!
Forgot to mention that she is currently berthed limiting the options so will go for the paint job solution (without scraping). I will use the paint remover once she is the yard!
thanks again
jay
Old 04-16-2011
I couldn't locate a replacement toe-rail for my discontinued Hughes / NorthStar 38, so remove and restore was my only option. It took me a while to find a place that could handle the 4 pieces each being about 20' long, but I did - a non-marine business near Hartford, CT. I'm sorry, I don't have the records and can't recall who they were, but it was a single proprietor and he charged me something like $350 - a good deal in retrospect given the durability.
Good luck.
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
Corroded Aluminium Hartley18 Gear & Maintenance 12 04-20-2008 07:18 PM
aluminium prep oz_hole Gear & Maintenance 3 01-22-2003 02:58 PM
aluminium extrusions caseyrunning Gear & Maintenance 3 02-28-2002 12:04 PM
aluminium extrusions caseyrunning Gear & Maintenance 0 02-06-2002 06:41 AM
