04-15-2011
Our rig will hum like a tuning fork in high winds if the main sheet has been cranked down on the boom. Typically, before furling back in, the main sheet is tensioned to pull the boom to the center, but becomes much too tight once the main is furled. It's bizarre, but all we need to do is relieve the tension by unlocking then relocking the clutch, which lets maybe 2 inches of line through and the boom has a little bit of play side to side.
Yours may not be this simple, but thought I would pass it along, just in case its as simple.
Jeanneau 54DS
