04-15-2011
Originally Posted by MarkSF
I'm going to install a Garhauer rigid boomvang on my Bristol soon.
I've seen past discusssions on how to attach the hardware to the mast and boom. Seems like a choice between :
Thread the holes and use bolts. Stainless or Monel?
Don't thread them and use rivets. Then there are Stainless, Monel, or Alu rivets!
I've got some evil-smelling anti-galvanic corrosion compound that I've used in the past and will use to seal the threads/holes.
Seems like if the mast material were thin, rivets would work best. You need 4 or 5 threads for bolts to have an advantage. Is the mast that thick?
Right now there's no boom vang at all so whatever I use should be an improvement!
I have one installed on mine and it has stainless pop rivets. the ony thing about pop rivets is it takes a large rivet squeezer to do the large stainless rivets
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
