Old 04-16-2011
DoubleEnder's Avatar
DoubleEnder is on a distinguished road
mooring pickup tune up
I have a pickup with fiberglass mast that the fiberglass is deteriorating. The woman "who must be obeyed" is getting splinters. Not good.
Any idea? Varnish maybe?
Thanks for any ideas!
Brian
Old 04-16-2011
Hudsonian is on a distinguished road
Buy a new fiberglass rod at Home Depot -- at my local HD we'd have choice of yellow or red both with white reflective bands. Reuse the float and weight. Epoxy the rod into the weight.
Old 04-16-2011
Minnewaska will become famous soon enough
I would get a new rod. You could wrap the entire rod in riggers tape in the meantime, but it wouldn't last long.
Jeanneau 54DS
Old 04-16-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Not sure I'd rely on epoxy alone. Usually held in with a cotter pin. Just use the weight as a jig and drill a hole through the rod. Did that once when the rod split at the bottom. Just shortened it a bit and used it for five more years.
Old 04-16-2011
Maine Sail's Avatar
You can use shroud protectors, the white plastic things with the split in them, or buy a UV resistant pick up buoy from Hamilton Marine or just use a boat hook, the aluminum never splinters...
Poly Coated Pickup Buoy
______
-Maine Sail / CS-36T
Old 04-16-2011
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Another tack would be to sand the rod lightly with fine paper then give it several coats of polyurathane.
Keeps the splinters from happening.
Another idea is to get your Admiral some sailing gloves.
Old 04-17-2011
Thanks guys for all the good ideas!
If mama ain't happy......nobody's happy!
Brian
Old 04-18-2011
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious is on a distinguished road
SWMBO should drive. You should wear gloves.
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
Old 04-18-2011
RobGallagher is on a distinguished road
Just tell her that the splinters keep it from slipping through he fingers. That should solve all your problems
Or you could give it a light coat of epoxy.
Mainsail, pickup line one please poopdeckpappy Gear & Maintenance 4 04-11-2010 12:36 AM
Tartan 30 C rig tune scottfree Tartan 0 11-26-2009 09:37 PM
Sun Fast 32 Rig Tune sinead Jeanneau 1 04-03-2008 01:05 PM
folding prop speed pickup mrkeith Gear & Maintenance 7 01-11-2007 12:48 AM
How to tune my rigging??? sailingsundance Gear & Maintenance 6 06-24-2003 03:04 PM
