Old 04-18-2011
Gary M's Avatar
Gary M is on a distinguished road
Marine Tex does not cost any more than West epoxy and you do not have to add a filler to thicken it. It is very easy to work with until you have to sand it.
  #12
Old 04-18-2011
mitiempo's Avatar
I wasn't suggesting that the void be filled with epoxy. i was suggesting the op call their tech people for expert advice - which is free.
If I was looking at a boat that had been damaged this much and repaired with expert advice and well done it would not be a deal breaker.
If I was looking at a boat with the same amount of damage and the owner just used either foam or Marine Tex and glassed it over without the advice of an expert I would pass.
Brian
You may post attachments
You may edit your posts
Bristol 24 keel repair oddasea Gear & Maintenance 10 04-04-2011 06:35 PM
Keel Repair CmdrObvious Gear & Maintenance 9 03-21-2010 11:28 PM
Keel Repair Lv56 Gear & Maintenance 0 09-23-2009 07:56 PM
Hull to Keel Repair weephee General Discussion (sailing related) 5 09-13-2009 12:53 PM
Keel repair..... clayjay Gear & Maintenance 2 08-02-2007 08:44 AM
SEO by vBSEO 3.6.1
