Old 04-17-2011
mtboat's Avatar
mtboat is on a distinguished road
Anyone like this unit?
It is a Whynter 45 Qt. Portable fridge /freezer. Found at Home Depot, for 500 bucks. I have shore power in marina, and plan on 4 Costco 220 ah 6v when not in slip. Any comments on the unit?
Whynter 45 Qt. Portable Fridge / Freezer - FM-45G at The Home Depot
Hard and fast
Old 04-18-2011
sidney777 is on a distinguished road
Looks good, amp useage looks good & low. I've had a similar model from Defender that is still freezing after 8 yrs. 12/24v and 110. Have you compared 110v amp usage and 12v amp usage to others ? Please let us know.
If you just want a small dorm size Freeze only; Walmart ($149./1.3 cu ft) has a bunch online. Are you going to hook batteries to inverter or run freezer unit with 12 volt while away from dock ?
Old 04-18-2011
mtboat's Avatar
Does anyone like this unit
I will go further. I live on a large lake, and won't be spending more than a day or two away from power. When away from the slip I would use it as a 12v, appliance. I have a laptop and lights, and no other power draws. I also have a portable gen for backup. Hoping to add solar later.
Hard and fast
Old 04-18-2011
ughmo2000 is on a distinguished road
You might take a look at Edgstar refridgerator freezer's also.
EdgeStar Refrigerators and Freezers
Tayana 37
s/v Adventure Bound
Old 04-18-2011
Waltthesalt is on a distinguished road
I'd check out the 12V amperage draw of the units you have under consideration. The can be significat differences between comparable sizes.
Old 04-18-2011
THEFRENCHA is on a distinguished road
Anyone knows where to find a 12v portable air conditioner?
Old 04-18-2011
mtboat's Avatar
I noticed the Whynter says 2.5 amps@12v, And the EdgeStar says 5.4 amps @12v. It appears to be the same exact unit but the size says 2 qt. difference.
Is one of them wrong?
Hard and fast
Old 04-18-2011
An amperage difference between similar sized unity is usually due to diferent kinds of cooling systems. It's usually cheaper units that have the highter draw. If they're using the same type of system then most likely the manuf. is using a different basis to measure the draw.
Old 04-18-2011
quote=THEFRENCHA;721603]---Anyone knows where to find a 12v portable air conditioner?[/quote]
---They don'tmake them.---* All I have seen are fans blowing air over/thru ice that are 12 volts. $99.00 and priced down to make your own with a coleman cooler and fans. See internet search and amazon.com
Should we buy this unit? alman Electronics 5 10-11-2010 09:44 PM
Harken MK II unit 1 ROSA Gear & Maintenance 15 06-12-2010 11:43 PM
ice Box Cooling unit Brunet33 Gear & Maintenance 8 10-15-2009 01:30 PM
second control unit MALALIA Gear & Maintenance 1 08-21-2007 10:18 PM
A/C Unit toribk Gear & Maintenance 1 11-17-2000 12:52 PM
