04-18-2011
Outboard Motor Mount: Butyl tape or caulk?
My C250 does not have a retractable motor mount. Instead, the outboard (a 15hp Honda) mounts directly on the transom. The fiberglass is protected by a SS plate on the front of the transom, and a ~10"x10"x1/8" piece of starboard on the back. I recently removed the starboard because there was some moisture behind it. It had been attached by four screws at the corners, with some caulk bedding between the starboard and fiberglass. The starboard popped off the caulk easily ('cause starboard don't stick to nuthin'), and I was able to scrape the caulk off the fiberglass easily with a razor blade scraper. Based on the properties of the film, I think it was 4200 that had been used.
I would now like to re-mount the starboard onto the transom. What do you suggest that I use? I'm considering butyl tape, but have some concerns. This plate will be subjected to fluctuating pressure and vibration from the outboard, so I am concerned that the butyl tape might "ooze" out over time, causing the starboard to loosen under the brackets - not something you want happening to an outboard. But on the other hand, if I could use a rolling pin to get the butyl tape down to about 1/16" thickness and coat the whole board with the stuff, the hydraulic lubrication forces to squeeze it out would be HUGE, so the bed should be stable. And its viscoelastic properties would be a nice shock absorber. (sorry about the engineer-speak)
On the other hand, traditional caulk would cure, so that it would never ooze out. In the case of the caulk, I would be more concerned about how to squeeze out the air from behind the starboard so that it does not accumulate water back there again. If I squirt a bead all around the perimeter of the board before placing it on the boat, there is no place for the air to escape. Should I use a slotted trowel to apply it (like flooring guys use)?
Which do you guys think I should use? Butyl or caulk? What type of caulk?
1998 Catalina 250WK "Take Five" (at Anchorage Marina, Essington, on the Delaware River)
1991 15' Trophy (Lake Wallenpaupack)
