Old 04-19-2011
xluke is on a distinguished road
Depth transducer compatibility
Hello,
I was wondering if depth sounder transducers are generally compatible with gauges across manufacturers or if they are manufacturer specific? They mostly appear to have similar physical connections (and one can always splice) but are they likely to cooperate across brands? Specifically I am considering using a humminbird gauge (can be had a good price) with my existing Standard Horizon transducer. Unfortunately, I can not find a replacement for my standard horizon and its LCD is badly sun damaged.
Thanks!
Old 04-19-2011
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Most transducers available these days come from the same supplier - Airmar.
You need to check that the transducer and the gauge use the same resonant frequency. If they do, they should be fine.
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 04-19-2011
Airmar has a pretty comprehensive listing of transducers, incl wiring diagrams on their site. Often the issue is with the cable connectors which tend to be brand specific. There are also variances in the designed frequency.
Airmar Marine Home
1984 Fast/Nicholson 345
Old 04-19-2011
HUGOSALT is on a distinguished road
If you are looking for parts or replacing your Standard
Horizon check out DMI ...I have bought parts, tranducers
cover etc.
http://www.dmimarine.com/parts/index.html
Old 04-19-2011
My error...have bought Datamarine parts from DMI not
Standard Horizon...but give a call, they might be able to
help or point you in the right direction as this is their business.
New Depth Sounder / Old Transducer (How To) Maine Sail Gear & Maintenance 10 07-09-2011 12:35 PM
Old Transducer with a new Depth Display? hriehl1 Gear & Maintenance 20 11-08-2010 10:51 PM
Depth transducer deandavis1 Gear & Maintenance 2 06-12-2010 07:52 AM
New depth sounder - Old transducer??? anderbra Gear & Maintenance 3 06-17-2009 09:02 PM
Garmin Depth Transducer. funsailthekeys Gear & Maintenance 2 11-04-2008 11:03 AM
