04-20-2011
Eletronic tach/alernator problems
Hello,
Almost all electronic tachs work on the output of the alternator. The is a seperate terminal on most tachs that is designated for this purpose. If the output stops for any reason, which could be many, the tach stops working.
If you are a bit mechanical and have a tester, you could check the output of the tach independant of your electronics, although you say the voltage was fluctuating down while the tach was not working.
I recomend taking the alternator and the voltage reguator to a good service shop and have them tested as a unit. Some alternators have an internal regulator, and they do fail from heat and vibration. A bit of internt research may help you determine what type your particular alt. has. When removing, make sure you make a good diagram of all wire connections and tape and tag the ends of all wires.
Good Luck
