Old 04-21-2011
brokesailor's Avatar
SV Skalliwag #141
brokesailor is on a distinguished road
Barnacles on gelcoat
My "old boat" is under contract, a 2007 Hunter 36. Out of the survey the potential buyer has asked I removed a cluster of barnacle skeletons off the gellcoat right above the bottom. I figure I can use a scraper to take most of it off but how do I get it totally off without damaging the gelcoat?
  #2
Old 04-21-2011
Minnewaska will become famous soon enough
I fear that no matter what you do, you will be left with evidence they were there. How large an area are we talking? I would want some contractual understanding of the outcome. The buyer can see them there and can't expect it to return to original condition. On the other hand, you should really get them off before marketing the boat, they would naturally be a detraction.
Jeanneau 54DS
  #3
Old 04-21-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
On and Off will do a pretty good job of softening them and making removal easy. They even suggest that use in their advertising. It's an acid and will damage the bottom paint, so suggest you protect it a plastic sheet.
  #4
Old 04-21-2011
SV Skalliwag #141
Maybe an area 2" by 8". What is on and off? Is that something I can get at WM? I googled it and nothing related came up.
  #5
Old 04-21-2011
jimrafford's Avatar
jimrafford is on a distinguished road
West Marine has it. I think it's called Mary Kates on off. It will do the job. It's a acid so make sure your not down wind when you spray it. You don't want it in your eyes.
Jim
S/V Deja Vu
CS 40
  #6
Old 04-21-2011
With such a small area, I would get surgical with a straight edge razor scraper. Be careful, it can dig in.
I wonder why this is an issue for the buyer. Are they going to walk if it doesn't look good when done or are they that picky. Sure, it shouldn't be there, but still seems off a bit.
Jeanneau 54DS
  #7
Old 04-21-2011
JimsCAL's Avatar
This is the stuff. WM carries it also.
http://www.defender.com/product.jsp?path=-1|10918|309314|311454&id=14027
You may post attachments
You may edit your posts
Barnacles on shaft wchevron Gear & Maintenance 22 03-02-2009 06:17 PM
Removing barnacles from outdrive Quickstep192 Gear & Maintenance 2 11-22-2007 11:34 AM
Barnacles, Props & Struts 7Psych Gear & Maintenance 9 10-14-2007 01:52 PM
barnacles Loualfr Gear & Maintenance 9 10-05-2007 01:10 AM
Barnacles Alden68 Gear & Maintenance 6 05-21-2007 09:47 PM
SEO by vBSEO 3.6.1
