prop won''t turn - SailNet Community
post #1 of 3 Old 07-04-2003 Thread Starter
prop won''''t turn
My friends Hunter legend 35.5 had the prop fouled by a mooring line. It wrapped around the shaft and killed the engine. We unwrapped it, the engine started fine but now the prop won''t turn. Is their some type of shear pin that I would need to replace on the prop shaft. If so, where is it? Its not my boat and
harley2007 is offline
post #2 of 3 Old 07-04-2003
prop won''''t turn
Last year I had the unhappy experience of reversing over my dinghy tow line. I''m told that everyone does it once....or were people just being nice?
This may sound simple, but are you sure that you have all the rope out? In my little (mis)adventure the rope moved up into the shaft housing. It was sufficient to bend the shaft.
raybies is offline
post #3 of 3 Old 07-05-2003
prop won''''t turn
Sounds like someone should get down in the engine compartment and see if the transmission is turning when put in gear.
If the shaft coming out of the transmission is not turning then you might want to call a professional.
knothead is offline
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 10:40 AM
how to remove folding prop? mcagney Gear & Maintenance 1 07-20-2005 10:23 AM
Prop for Pearson 35 gbeardmore General Discussion (sailing related) 2 05-27-2001 12:08 PM
Prop for Atomic 4 gbeardmore Gear & Maintenance 0 05-03-2001 01:15 PM
Prop for Pearson 35 gbeardmore Gear & Maintenance 0 04-24-2001 12:49 PM
