Old 04-22-2011
xluke is on a distinguished road
Boat cushions from stock foam
Hello,
Does anyone know a good way to cut down foam to make boat cushions? Maybe a hot wire, but how? Or just a razor? Some sort of saw? Finding foam on the bulk market is pretty cheap but I don't know how I would cut it to size. (of course upholstery would be another hurdle but one step at a time!).
Thanks!
Old 04-22-2011
nightowle's Avatar
nightowle is on a distinguished road
I've read that an electric carving knife is the best way. believe it or not!
________
S/V Don't Panic!
O'Day 27
Seattle, WA
“Navigare necesse est, vivere non est necesse” To Sail is vital, to live is not.
Old 04-22-2011
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
Electric carving knife works. You cant really just use any type of bulk foam for interior or exterior cushions.
Choose the wrong kind for your particular area you have major mold and mildew or it retains moisture. Good foam is not cheap either. If you are going to go through the effort of replacing interior cushions, the job is a large one and there is no sense skimping on one of the two major components ( foam and upholstery fabric), Read up on doing this..
dave
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Old 04-23-2011
I'd rather be sailing
labatt will become famous soon enough
Another method is to get a 2x4 with clean/sharp edges and push it down where you want to cut the foam. Then cut the compressed foam along the 2x4 with a utility knife (the better shape the edge of the 2x4 is in, the cleaner the cut). We didn't have a hot knife and this method worked well.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 04-23-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
I'll second C2S's comment getting quality foam. Upholstery foam isn't cheap. It has to be firm enough to keep you from "bottoming out", without being so dense as to retain moisture for too long. The latter property being even more important on a boat. Cheap foam usually sacrifices one of the properties for the other. Also, a good quality cushion often has quite a bit of polyester batting, in addition to the foam. When this batting is missing the cushion will look too flat and feel like a "cheap foam cushion" (for lack of a better descriptor) when you sit or lie down on it.
Old 04-23-2011
genieskip is on a distinguished road
Sailrite's website has a number of free videos on the subject of making cushions. They also have a DVD for around twenty bucks that explains everything. Using their info I redid all the cushions on my boat and a number of them on my son's junker.
I used an old electric knife to cut foam and that works the best. The two serrated blades working in opposition give the best cut.
genieskip
Northeast
J40
1991
Old 04-23-2011
B'Causeican
spec2 is on a distinguished road
I made my own exterior cushions for my C &C 99 after pricing out a few local and web-based shops. First, find a local Foam company. I found one in Hartford CT. Make cardboard templates of your cushions. Be sure to mark the templates Port/Starboard/Top/Bottom. Bring templates with you to the Foam shop. Explain the application. The foam needs to be dense, but more importantly, it needs to breathe. Have the Foam shop cut the foam for you. They have the correct equipment. Next step is to Jo-Ann Fabrics for Sunbrella. Wait until they have a sale. Check out their Web site. Take your foam there. They have well-trained staff that will measure the correct amount of fabric you need. I added zippers enabling me to clean as needed and straps like those found on a backpack to cover my open-transom seat. Found all the stuff needed at Jo-Ann's. Then you need a seamstress. Since you're already at Jo-Ann's, I suggest you ask the staff if anyone would be interested in completing your project. Craigslist is helpful. Also, you can find seamstress's at stores like Macy's etc... Find one of these nice ole folks in the store and ask 'em if they do work on the side. At the end of the day, I saved about 30% doing this on my own. A bit of running around here, but we're all cheapskates....aren't we?
Old 04-23-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
I second the method of using an electric knife.
I got my foam from a vendor I found on e-bay. You do need to know what the density numbers mean to get the right stuff.
I found good prices (and cheap samples) for fabric from FabricGuru.com. There are some brands that are a little cheaper than sunbrella (and probably not as good).
Old 04-23-2011
HPLou is on a distinguished road
Send a message via AIM to HPLou
An electric knife will definitely do the job in cutting the foam. Another option would be to use a really sharp fillet knife. I've used both with very good results.
Old 04-24-2011
QuickMick's Avatar
QuickMick is on a distinguished road
lots of good cushion ideas here:
http://www.sailnet.com/forums/gear-m...-smooshin.html
a real slick idea of using beans and foam (loose) for a bean bag effect.
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Which foam for interior cushions? jephotog Gear & Maintenance 7 08-26-2009 08:35 PM
replacing foam in berth cushions wumhenry Gear & Maintenance 14 09-13-2007 10:55 AM
Boat Cushions and Foam j1budo Gear & Maintenance 15 02-23-2007 02:42 PM
Closed cell foam cushions Fishboat Gear & Maintenance 4 02-03-2004 05:19 PM
Foam as insulator on Alum. Boat pierot69 Gear & Maintenance 0 04-02-2001 08:30 PM
