04-24-2011
I suspect that the support under the compression post has failed in some way, possibly rotted. The compression post support is like the mast step on a keel stepped boat, subject to the same stresses. I would take out the post(mast off, of course), and find out what the problem is. I would not put anything adjustable in a permanent solution. It may "adjust" itself while you aren't looking... not a good thing in your rigging. Ford
