Old 04-24-2011
MikeinLA's Avatar
MikeinLA is on a distinguished road
Tank Monitors
Hi all. Thinking of adding monitors for 2 water, 1 holding and 1 fuel tank. I'd appreciate any suggestions or recommendations based on what you might have tried and had good luck with. It doesn't have to be an integrated system for all tanks, but that would be nice. I'm leaning toward the Tank Tender, but I know there are newer systems out there. Any thoughts?
Thanks, Mike
Old 04-24-2011
treilley's Avatar
treilley is on a distinguished road
Tank tender is good as it is ver low maintenance and does not require any electricity. Installation is from above.
The Scad Profile is the best electric monitor by far and fairly easy to install.
I have used both on different boats.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
Old 04-24-2011
CaptainForce's Avatar
I'm very fond of my SCAD "SOLO" holding tank monitor because there is not intrusion of probes or any openings into the tank.
I am able to view intervals of fill levels easily and accurately.
Take care and joy, Aythya crew
Old 04-24-2011
Gary M's Avatar
Gary M is on a distinguished road
I am looking for a replacement of the basic dial and float that mounts in the top of the water tank. Have not been able to find one online, any suggestions?
Thanks
Gary
Old 06-11-2011
chrisferro is on a distinguished road
I have an Electrosense monitor on my boat. It works great.
chris
Old 06-11-2011
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
I also have the SCAD monitor for thee holding tank. It works well and does not need an internal float. The make 3 tank monitors also. Easy to install as well.
Dave
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Old 06-12-2011
GaryHLucas is on a distinguished road
I've often thought of building a multiple tank monitor using a principal I worked on thirty years ago to monitor the level in underground tanks. You build a cheap little manifold from plastic pipe fittings. A flexible PVC hose goes into each tank with weight on the end to hold it on the bottom. Each tank hose connects to the manifold by 1/4 turn valve. An outboard fuel bulb is connected to the manifold. Then you have a vertical clear U-tube on a bulkhead with colored water in it. One end connects to the manifold, the other is open to atmosphere near the ceiling. To check a tank you open the valve for the tank and start squeezing the bulb. The water in the U-tube is displaced from one side to the other until the air starts bubbling out at the bottom of the tank tube. The water level change indicates the inches of level in the tank. Since fuel is lower in specific gravity than water the level rise will be scaled slightly less than actual inches. Close the valve after checking.
Gary H. Lucas
Holding tank monitors emaitz Gear & Maintenance 12 07-06-2011 10:17 PM
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 07:55 PM
Can I build a fiberglass tank inside leaking metal tank? dohenyboy Gear & Maintenance 2 11-11-2007 10:08 PM
Tank Monitors saillavie38 Gear & Maintenance 1 01-02-2007 11:58 PM
BMF monitors Navigation Charging Strategy @ Sea Dreamer NewsReader News Feeds 0 04-20-2006 06:18 AM
