04-26-2011
I also agree about a completely separate system, i.e., the 2nd radio attached to a 2nd antenna.
However, if you must use just one antenna, a manual coax switch (such as the not inexpensive Alpha Delta) is a good way to go. It must be placed in a highly visible place, though, and clearly marked so that you don't try to transmit when the switch isn't in the correct position.
I don't like or trust the automatic relays or splitters. Aside from the insertion loss and need to connect to an external 12V source, there's always the possibility of a malfunction. To my mind, this is intolerable in what is arguably the most important safety device on your boat.
Bill
