04-24-2011
Most of the time the cables are run within the pedestal support tubing, our power cable for the autohelm drive unit runs inside the pedestal proper (we have link/lever rather than chain/wire) Of course for this to be possible the tubing supports and pedestal must be open and somewhat accessible from below.
Do you plan to use that side mount shown? If so then, assuming that you are open at the bottoms simply drill a hole in the tubing nearby and feed the cable through. A light messenger line may help, run that through first, or a long, thin welders rod can be used to push wires through if that might work better. A grommet or some sort of seal should be used to seal where the cable goes through.
If the hole is immediately under the collar of the side arm bracket it may have some 'protection' from rain intrusion.
1984 Fast/Nicholson 345
