04-25-2011
Break, curse, fix, repeat
The previous posts have good ideas to check for cracks, and I've also heard the use of cotton balls is useful as they will snag when rubbed lightly along the fittings if there are cracks or meat hooks in the wiring.
For me though, having replaced all my rigging a year or so ago, I found it easy and straightforward and worth doing as a prophylactic. I believe I have heard 7-10 years is a good lifespan in typical, non-tropical conditions. It is not terribly expensive, really, considering the consequences of failure.
My philosophy on these sorts of things relates to the ratio between my anxiety and the actual risk/consequence of failure. Some things really weigh on my mind, and even though they may not be about to fail, it is worth replacing them just to stop thinking about it. So, if you are worried about your rigging, and have heard or had bad experiences with failed rigging, you may want to just do it as it is fun and gives peace of mind. If not worried about, you may find reassurance from not finding cracks to let it go another year or two.
Quick story: Friends of mine on San Juan Island took their Ranger 33 out for a sail, already being somewhat concerned about the age of their rigging, and had their headstay snap off while under sail in 20 knots of wind. Quick moves and luck kept them from losing their rig, but they immediately replaced it all, and used Colligo Marine gear to be one of the first in the NW to have Dynex rigging. Don't know the long term happiness with that though.
Aeolus
Gulf 32
Bainbridge Island, WA
