04-26-2011
I use a Develbiss HVLP gravity feed gun, they make a good job and are affordable. They come with tips up to 2.2 hope ya have a big compressor, i need a 5.5hp gas compressor and have an additional 80 gallon reserve tank. I also use a graco Mark V airless paint machine, works great, overspray is nil. Have all cleaning apparatus set up and ready to go before beginning, and prepare for having to roll and tip it out alone if your machine should malfunction, or be prepared to toss and try again. If you wanna buy a useful spray setup, go to a pawn shop and find a small airless, then buy a new tip for the gun, and you will be good to go. Graco makes good little sprayers that are perfect for this, just don't forget to CLEAN IT!  Remember to check the MSDS Sheets, or phone the paint MFG. so you buy the correct filters for you respirator. Neglecting this might/will kill ya in a day or so... if ya didn't know.
Why, why, why? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
