Old 07-06-2003
primowon is on a distinguished road
Mast Ladders
Has anyone any experience with these? Which are preferred and safest? Where can I find used ones? What is a reasonable price? I''m interested in the ones that can be attached to the main halyard.
Thanks
Old 07-06-2003
joub is on a distinguished road
Mast Ladders
When you specify a "mast ladder" are you excluding other ways to ascend the mast?
The ATN top climber ( think that is the name) is a great way to get up the mast by yourself. I purchased a couple of ascenders from a mountain climbing supply house. Sewed up a harness for my feet, and utilized my existing bosn''s chair to make a copy of the ATN device. It works great! Almost makes climbing the mast fun! Total cost was around $125.
Fairwinds,
Jim
Old 07-07-2003
Mast Ladders
Thanks for your response. Do you have an address for the mountain climbing supply house? Also I did not understand the part about sewing up a harness for your feet? This sounds like a great alternative way to climb the mast. Again, appreciate the imput.
Bern
Old 07-07-2003
joub1 is on a distinguished road
Mast Ladders
Take a look at http://www.riggingonly.com/atn_top_climber.htm
If you aren''t familiar with the ATN top climber this web page will show you one!
The top climber sells for $285, which may be a little steep for some, but is not an unreasonable price. I elected to make my own as I already had the bosn''s chair and a heavy duty sewing machine.
The Ascenders, which are the heart of the system,are widely available from most mountain climbing equipment dealers. Do a web search for Mountain climbing equipment and I''m sure you will find several sources.
Fairwinds,
Jim
Old 07-07-2003
Thermal is on a distinguished road
Mast Ladders
I got some ascenders and a climbing harness to go up my mast a few times and it worked fine, except that I was tied to a dock in a marina. Dangling 50'' over my deck, I thought this wouldn''t be so cool if I was tied to a mooring, or anchored somewhere, so I bought 19 mast steps - about the same price as one of those Top-Climber things. If you still want go with the ascenders, I got ones made by Petzl from REI (rei.com). You can also get a harness and ready made webbing loops (mine were 48") there. You''ll also need at least a couple of carabiners.
Old 07-08-2003
928frenzy is on a distinguished road
Mast Ladders
I bought the ATN Top Climber at the last Annapolis Boat Show (from the designer). It works very well and can be used on any 1/2" line. Moreover, I can swing from one speader to another and still be quite secure. (You can''t do that with mast steps.)
I thought about mast steps, but decided they would add too much weight aloft. However, I did install two of them 18" from the deck to help us install or remove the main-halyard shackle from the sail-clew.
~ Happy sails to you ~ _/) ~
Old 07-11-2003
Mast Ladders
I don''t believe climbing the mast with ascenders would be any different at anchor or at a dock. If you keep the ascending line taut there is little room to "dangle about". In fact, if I want to work on my spreaders, I have to leave a little slack in the line to allow me to swing far enough away from the mast to get out to the spreader tip.
Jim
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
