Old 04-27-2011
timangiel's Avatar
timangiel is on a distinguished road
what is holding sink in place?
I have a stainless steel sink in my galley that I want to remove. I am familiar with the manner in which sinks are installed in a house, with metal clips on the underside of the countertop. When I took a look under this sink I did not see any kind of clip or fastner on the under side. Do they glue sinks in place?, and if so how do you remove them? Its a boat from the late 70's and I'm pretty sure its original.
Old 04-27-2011
Beersmith's Avatar
Sailing to surf
Beersmith is on a distinguished road
mine was held on by silicon sealant, which I had to separate from the countertop with a hammer and scraper/chisel; as well as some metal clips
My boat rebuild/sailing blog:
Please read and provide comment to my entries!
Old 04-27-2011
CaptainForce's Avatar
My '73 Morgan has the metal clips on the underside of the countertop as you descibed. What do you find when you run a thin blade under the lip of the sink at the top of the counter? Take care and joy, Aythya crew
Old 04-27-2011
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
If there are no clips then it's probably just caulked in place, and the plumbing conection under the sink for the drain helps hold the sink down.
Old 04-27-2011
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
If it's glued in, then start in one corner with a few putty knives/butter knives, wedging them on top of ea. other. between the sink and counter. then slide a thicker screwdriver in between them to act as a wedge and use a long razor knife to cut the seal as you work around the whole sink.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
Old 04-27-2011
MikeinLA's Avatar
MikeinLA is on a distinguished road
I'm still hunting for the person who installed the sink on my Cat 36. The sink has a lip which sits on the fiberglass liner, then the countertop was laid on top. I have a beautiful new sink to replace it (it's rusty) and I'm gonna have to CUT it out. Fun fun.
Mike
Old 04-28-2011
JiffyLube's Avatar
Grasshopper
Mike
You might be able to cut it out from the bottom side with something like a Rotozip or maybe even a Dremel (keeping the top side hole the same), but I'm pretty sure you can do it from the top side if you take the fawcet off...but then you have to use a slightly larger sink for the larger hole.
Old 05-01-2011
timangiel's Avatar
I don't know how I missed it previously, but after getting back down to the boat and taking a good look with a flashlight, I noticed a washer and nut on the underside of the countertop near each corner of the sink. So, I removed them and the sink came right out. The sink had threaded studs at each corner on the under side of the lip that prodruded through holes drilled into the counter top. They were hard to see due to some very tight spaces.
Old 05-01-2011
MikeinLA's Avatar
Yes, I can cut it from the top, no room from underneath. The new sink has a lip which will sit on the countertop and allow plenty of support all around. I haven't decided if a Dremel will cut the Stainless or if I need an angle grinder with cutting blade. I'm still summoning up my courage for this job.
Mike
Old 05-01-2011
MacGyverRI's Avatar
Mike
Try to find a "Cobalt" cutter for a Dremel/Roto zip, regular bits wont really cut well.
A high speed metal cutting blade (the thin ones) on a high speed grinder will do it. Don't use a slow speed blade on a high speed grinder since they can blow apart.
Cal 34 sink cwyckham Sailboat Design and Construction 3 05-25-2010 09:10 PM
Leaking holding tank causes boat to almost sink? davidpm Boat Review and Purchase Forum 23 02-14-2010 06:58 PM
How do I fix my sink? bestfriend Gear & Maintenance 18 07-22-2007 05:38 AM
Holding conduit in place while fastening dnseal Gear & Maintenance 6 11-27-2006 05:45 PM
One sink or two rleslie herSailNet 1 01-02-2005 11:21 PM
