Decreasing Oil Pressure - SailNet Community
Blogs
Old 07-06-2003
primowon is on a distinguished road
I have a 34'' 1988 Sabre with a 27 Westerbeke engine (900 hours). The book states the normal oil pressure range is 40-80psi. I note that when first starting, the pressure is about 70. After approximately 1 hour it will have decresed to about 50psi. After 2 hours of continuous motoring it will have decreased to below 40. I''m afraid of the answer; I''m sure it will be expensive. Any opinions are welcome. Thanks.
Old 07-06-2003
joub is on a distinguished road
Generally, low oil pressure is an indication of bearing wear. The engine oil pump can pump a certain volume of oil which is distributed to the various bearings in the engine. As these bearings wear, they allow more oil to flow past them due to a greater clearance between the bearing and the surface the bearing operates against. Eventually, the oil pump is unable to pump a sufficient volume of oil (because of the leakage) and the oil pressure begins to fall.
Oil pressure normally falls as the oil reaches a higher temperature and becomes thinner, but when it falls below the manufacturers oil pressure range it usually means excessive engine wear.
If you are lucky, it could be the oil pressure relief valve is stuck in the open position which can also cause a similiar indication. Unless the engine has been abused, 900 hours is not normally enough time to experience excessive bearing wear.
An evaluation by a good boat engine mechanic should be done before you accept the worst case scenario.
Good luck!
Jim
Old 07-07-2003
fourknots is on a distinguished road
40 psi is not unusual for a hot diesel engine - in fact I''d say it was pretty good. If you see less than 15-20 with a hot engine at idle, there could be a problem, but some engines are even ok with that. I''d say not to worry.
Old 07-07-2003
clayton is on a distinguished road
I have a Perkins 30hp that does the same thing. Starts at 60 and slowly goes down to 40. Normal, don''t worry!
W60 - No oil pressure after oil change??? pma_foyl Gear & Maintenance 9 12-01-2004 10:45 AM
Fresh water pressure, help nauticalrich Gear & Maintenance 5 07-28-2003 07:11 AM
Oil pressure alarm question i670684 Gear & Maintenance 1 12-18-2002 01:40 PM
Avon high pressure floor mikemosabe Gear & Maintenance 5 08-17-2002 04:44 AM
Engine Oil Pressure Problem msamelso Gear & Maintenance 2 02-20-2001 07:25 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
