04-28-2011
Lies about her age
Age has allot to do with type. 12 was phased out in the early 90s (CRS here) most likely it's R-12 if it's old. An experienced tech can tell by pressure at a given temp also. 134 is not hard to mistake should you have it, it stains everything. R-12 (one reason we loved it) runs very close in operation pressures to the temps it was working at.
Just a few refrigerants used in such systems,
refrigeration, 12, 22, 409A,134 (new generation), 22 in ac systems is being phased out for 410A, 134 417A, I guess there is a "marine" standard for types of refrigerants and system designs.
409A, 404A, (not likely) "hot shot" (is a mix made for "drop in replacement of 12)
Confusing? Very! There are hundreds of types of refrigerants for hundreds of types of systems, and manufactures design around those they choose for the application. Fortunately, your only likely to have R-12 in your systems.
I'd love to see photos of your system. Dual evaporators or dual circuit?
what are the symptoms or problems? Caution.. very very common mistake, small systems like this use ounces, not pounds of refrigerant.
