Old 04-28-2011
oomfh is on a distinguished road
Need a watertight wire splice
I've made my share of wire connections in the past. Have also used heat shink tubing when joining only two wires together.
How do you make a watertight connection when splicing a new wire into the middle an existing run?
12 gauge, 12 volt, Ancor
Old 04-28-2011
SVPrairieRose's Avatar
SVPrairieRose is on a distinguished road
I would suggest a junction box. I have seen two wires fed into one heatshrink connector before, not ideal. I believe anchor electric makes three way connectors. I would use a junction box personally. Good luck.
Old 04-28-2011
GaryHLucas is on a distinguished road
McMaster Carr sells the adhesive used in the waterproof heat shrink tubing in a strip form. If you use a piece to fill the gap between the two wires coming out of one end of the heat shrink tubing you'll be sure that you get a good seal.
Gary H. Lucas
Old 04-28-2011
Heat shrink tape
Gary H. Lucas
Gary, is this what you are referring to?
McMaster-Carr
Old 04-29-2011
Omatako's Avatar
Omatako will become famous soon enough
You need one of these
ELECTRICAL SPLICES
Arthur C. Clarke
Old 04-29-2011
McMaster-Carr
No, look at the bottom left of the page:
McMaster-Carr
Old 04-29-2011
pdqaltair's Avatar
pdqaltair is on a distinguished road
The thicker tape is butyl. That's interesting.
McMaster-Carr
I have some waterproof splices to make tomorrow.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Watertight Cockpit Lockers tager General Discussion (sailing related) 4 03-25-2010 08:30 PM
Wire to rope Halyard Splice tara42 Gear & Maintenance 8 03-16-2010 04:26 PM
Help w/Splice (in Tacoma, WA) t1t0 Gear & Maintenance 1 09-23-2009 08:56 PM
Watertight seal on thru-bolt deck hardware??? SiXeVeN Gear & Maintenance 12 09-14-2009 09:22 AM
End for end splice ke4tfh Gear & Maintenance 2 04-16-2004 09:24 AM
