Interprotect Barrier Coat Questions - Page 2 - SailNet Community
post #11 of 13 Old 04-29-2011
Maine Sail's Avatar
Originally Posted by cghubbell View Post
According to the Interprotect Product sheet when overcoating with VC-17m the Interprotect layers are supposed to dry for 24-36 hours, then be sanded with 180-220 grit paper.
So, it looks like the thumb prints are more for timing the Interprotect layers than tying in with my anti-fowling. This process only applies to the VC-17m or VC-17m Extra though. All other anti-fowling paints must be applied in the overcoating window.
Lotsa details to manage with these boat projects!
Sorry, my bad, I missed that part about the VC. VC does not chemically bond with a barrier coat like many bottom paints do..
The Interprotect layers do not need thumb print timing and can be re-coated once dry. If you try it with thumb print it can lift and soften the lower layers. Ask me how I know.... Doh'.... The open times are quite long before needing to sand IP2KE for another coat.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 13 Old 04-30-2011 Thread Starter
Beneteau F310 ~ APOTHIC
cghubbell's Avatar
Dock
Success!
Just wanted to check in and thank everyone for the moral support leading up to the project. I got two coats applied today, and she looks like a new boat. It's nothing short of amazing.
I ended up using a solvent resistant mohair brush in a nap slightly finer than what Interlux called for. Why? Because it's what the chandlery had in stock and I didn't want to blow time driving elsewhere. The finish is certainly not gelcoat-smooth, but it's very, very nice compared to what I started with. I have no complaints.
It was a little tricky figuring out how thick to roll it on. I get the impression that Interlux wants it rolled on fairly heavy based on the number of coats they recommend and how far each batch went. Takes quite a bit of concentration to avoid sags at that level, but it is very do-able. My second coat was a day and night difference from the first. A nice quality of IP2k is that its thickness hides goofs very efficiently on subsequent coats.
There were ZERO issues with quick curing. I mixed up 50% of the product per batch and let it sit for the recommended 15-20 minutes to evacutate air bubbles. I'd occasionally see a little skim on the surface of the bucket's contents, but 10-15 seconds of swizzling dissolved that back into the soup.
One gallon of IP2k covered about 1-1/3 of my hull, so I think I'm going to end up over Interlux's recommended thickness. No harm done there.
Here she is at coat #2 where I left her this evening...
From Restoring Ravat
Tomorrow morning it's back out to the yard to finish up coats 3 & 4. If I'm lucky I may even get the new bow hatch installed while coat 3 dries. Whew!
Beneteau F310 ~ Apothic
PYC, Lake Ontario
cghubbell is offline
post #13 of 13 Old 04-30-2011
One of None
deniseO30's Avatar
Last year I helped a friend do the coat on his Erricson 27. the old gel coat was all spider cracked I mean the whole bottom too.. He completely stripped all the old paint, and did like 6 thick coats of 2000E. Not a single crack has telegraphed through the barrier coat a year later. So it's not only a barrier coat it's also a new skin.
My last project!
deniseO30 is offline
Epoxy Barrier Coat over Gel Coat? lizardheadone Gear & Maintenance 4 01-14-2016 09:08 PM
Bottom paint over Gel Coat without Barrier Coat? WagTheDog Gear & Maintenance 17 07-15-2012 07:33 AM
Help choosing my barrier coat system: Interprotect vs. West System vs. Other? Beersmith Gear & Maintenance 30 02-09-2011 01:10 PM
Tips for barrier coating with Interprotect? mrybas Gear & Maintenance 4 08-20-2010 10:45 AM
What is a barrier coat? sailboy21 Gear & Maintenance 9 02-12-2008 03:55 PM
