Old 04-30-2011
Neicy is on a distinguished road
Insulate Icebox Using Foam Spray
Does anyone have any experience with the Dow Froth-Pak Polyurethane Foam kit for trying to insulate around the outside of an existing ice box?
Is this a recommended method? Thanks
Old 04-30-2011
newpbs is on a distinguished road
Foam Board
I insulated my ice box last summer. It helped a lot. Wish I had done it earlier.
I considered spraying insulation around but I decided to use closed cell insulation instead. Is is cheaper and easier to install. I did use foam insulation from the hardware to adhere the board and fill gaps. When the foam cured the insulation was solidly in place.
Good luck
Old 04-30-2011
mgiguere is on a distinguished road
We did spray 2 or 3 cans of foam (from Home Depot) around the perimeter of our ice box by drilling access holes. I'll let you know this summer if it worked.
Old 05-01-2011
ScuzzMonkey is on a distinguished road
I didn't use that particular product, but when we re-insulated our icebox a couple years ago, we did use spray foam in some areas. Where we could get access, we used stiff panel insulation, but along the curve of the hull and in corners we used the foam. On the whole, the insulation job has improved the cold retention in the box but I can't say to what extent the foam itself is responsible. It has proven very durable, which is a plus.
Old 05-01-2011
janmayen is on a distinguished road
Send a message via Skype™ to janmayen
Using this method be aware to use a spray form that does NOT increase in volume. Expanding foams are very powerful and might destroy the furniture if there's not enough room to expand. Also you cant see if it realy has filled all around the icebox.
_______/)____/)__/)____/)______/)_________/)____
Insulate Ice box on Apache 37 mgiguere Gear & Maintenance 4 06-27-2010 10:16 PM
Insulate only to the waterline? GilStump Gear & Maintenance 17 12-18-2009 04:31 AM
Using spray foam to seal a leak Survivor Gear & Maintenance 10 11-10-2008 01:47 PM
spray foam + inflatable boat = save it or kill it? piggybeach Gear & Maintenance 22 07-16-2007 04:43 PM
Icebox to Refrigerator offline2004 Gear & Maintenance 12 01-26-2007 04:02 PM
