05-02-2011
Break, curse, fix, repeat
Freerider, I echo the comment of paulk questioning the need for the stiffening. My primary thought would be to do some epic research into the boat and read other experiences. I would also see if it was possible to contact the builder/architect as they might have knowledge about any weaknesses that happened over time.
Casey has good descriptions of how to do the stiffening with stringers, and that is probably the easy part. My view on the pros/cons of adding stringers simply for the sake of extra stiffening is that stringers in the necessary places may be A. Hard to reach B. Take up storage space better used for something else and C. Take time away from other projects you are better off doing!
On this last point, I believe every one of us, no matter how diligent, recognizes that there is an endless list of projects we could be tackling. For out of the water projects, what about a super clean and treated prop? Does your hull need a good polish? Others like removing and rebedding all deck hardware comes to mind. Checking all mast fittings for corrosion. Removing and rebedding all windows. So many things that need doing so regularly and yet we all lack sufficient time to do them when we would like. So I guess I am asking about the opportunity cost of doing this project versus others.
Maybe, after all things considered, you just wanna do it because you wanna do it, and the damn boat is yours to do with what you want and you'd like the fiberglass practice. Well then...
Have fun!
Aeolus
Gulf 32
Bainbridge Island, WA
