Old 05-02-2011
CuriousChris is on a distinguished road
Cockpit floor needs finishing, Help!
I've just about finished replacing the rotten plywood core of the cockpit in my Tanzer 22. I still want to put a final layer of cloth/resin on the top of everything but after that I'm a bit vague.
I'm trying to figure out what final finish I need to put on.
I expect my surface will be epoxy resin/some epoxy fairing compound.
I've stripped the previous owner's paint, and the gelcoat no skid pattern so I have a relatively smooth surface.
I'm not looking for perfection but it should look ok. My boat is almost 40 years old.
I can't imagine putting a shiny surface because it needs to have some non skid but then ???
I'm pretty much a novice when it comes to refinishing and I don't have spray set up.
I sail in Lake Ontario and the boat is out of the water in winter but the cockpit gets wet.
Anyone have a favourite material?
Thanks
Christine
christinedemerchant.com/tanzerfloorrepair.html
Old 05-02-2011
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
I like Interlux Intergrip additive. add it to paint and roll it on- provides a really nice non-skid that matches the paint colour of the rest of the cockpit exactly because it is the same paint.
It's 5 o'clock somewhere:
Old 05-02-2011
Nice Blog!
I will look into this. Matching colour is a good thing.
Christine
Old 05-02-2011
deniseO30's Avatar
Lies about her age
Chris you may be able to roll a piece of window screen on a paint roller and roll it on the cured but still soft epoxy. Timing would be important because there is a point when it's still soft but not tacky. Then paint with epoxy primer first. many paints won't stick to epoxy very well. Just a thought...
Old 05-02-2011
Thanks, Chris!
Old 05-02-2011
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Have a look at SeaDek Marine Products. A small pad overlaid on you cockpit floor may be just what you need.
Wood cockpit floor mat blanchardkeith Gear & Maintenance 9 01-26-2011 08:00 PM
What's the best tool for cutting through the cockpit floor? donhaller Gear & Maintenance 35 01-19-2009 02:12 AM
Finishing a Cockpit Table ahalfon Gear & Maintenance 22 07-18-2008 09:14 PM
Teak Finishing Ronbye Gear & Maintenance 11 04-06-2006 10:43 PM
Teak Cockpit Floor Kit Tom Wood Gear and Maintenance Articles 0 01-03-1999 07:00 PM
