single vs continuous line furling - Page 3 - SailNet Community
 6Likes
post #21 of 23 Old 08-24-2013
glymroff's Avatar
Location: Winter/Spring - Sailing, Summer/Fall - Vermont
Re: single vs continuous line furling
On my gal's Pearson26 we have a continuous line (old hood IIRC). We hate it. The line always jumps the wheel and jams or the line comes completely out. It does work a bit better if there is back pressure, however it still screws up. We have not had one sail where this does not happen.
At first I thought it was because the line diameter was to small. So I've tried two other diameters. No bueno.
The first chance we get to convert to a single line drum it will happen. Although it's pretty old and I'm not sure what to even (or where to) get a conversion.
Just my 2c :-)
glymroff is offline
post #22 of 23 Old 08-24-2013
THEFRENCHA's Avatar
Totally agree with Mr Canada . Love my old Hood mine was getting old and I just refurbished it for about $100 Looks good for another 10 years.
The continuous lines is long enough to end next to steering wheel
Very easy to handle . Line will not mess in drum if you have a couple of guides on your stanchions especially closer to the drum .
Should not unfurl if you put some tension on the line and cleat it when at the mooring.
THEFRENCHA is offline
post #23 of 23 Old 08-24-2013
we are thinking of getting a furler so this has been great information, thanks
rlaskowsky58 is offline
single line reefing LS2009 Gear & Maintenance 3 09-22-2010 09:46 AM
Single handing w/o roller furling Stryker72 Seamanship & Navigation 25 03-17-2008 11:01 AM
Line Choice for Single-Line Reefing lmitchell Gear & Maintenance 6 04-12-2007 01:38 PM
Shorter Single Line Reef Line dnseal Gear & Maintenance 6 11-26-2006 05:58 PM
single line reefing? jbarros Gear & Maintenance 8 05-16-2003 06:27 PM
