05-02-2011
Break, curse, fix, repeat
Maybe I'm alone in this but can you clarify if this is your engine mounted pump? Sounds like it is. If it is, I sympathize. I have an Oberdorfer pump on my Universal now but the old one was a Sherwood that caused problems.
You say "nuts", which makes me think there are bolt shafts coming out of your block. If so, you surely would not want to damage them.
You'll hear here about PB Blaster, which is great stuff that penetrates and loosens things. You can also, usually, apply heat with a propane torch to the outside of the nut, which both expands the nut but also causes cracking in the corrosion. If you can't get a socket on the nut, what about an open ended wrench? What about vice grips?
A photo would be enormously helpful to people here, as many have deep experience with frozen nuts and bolts and there are a variety of approaches depending on location and materials.
Aeolus
Gulf 32
Bainbridge Island, WA
