Old 05-02-2011
MarkSF is on a distinguished road
Rope choice for main outhaul and cunningham
I'd like to replace the old main outhaul which has gone as hard and brittle as rock!
I think a very low stretch rope would be advantageous? Is there a reasonably priced one without going for dyneema? It's only 12ft long so I guess dyneema would be affordable, just sounds over the top.
Thanks!
Old 05-02-2011
bwindrope's Avatar
Break, curse, fix, repeat
bwindrope is on a distinguished road
Can of worms here. If it's only 12 feet you have a smallish boat so weight may or may not be a big consideration. I've had great luck with Samson LS or XLS. They are standard polyester lines that don't get racers too excited but are cheap and very dependable/easy to work with. Can be used for all running rigging on a cruising boat. Your bifurcation would seem to be whether weight and stretch are your biggest concerns, or whether 90% the performance and 30% the price is good enough.
Endless online opinions and resources on this. Working with lines is one of my favorite things about being a sailor. I look for any opportunity to splice and rig new lines!
Aeolus
Gulf 32
Bainbridge Island, WA
Old 05-02-2011
It is a Bristol 31.1. That outhaul only goes from the clew to 2/3 along the boom so it's not very long. Maybe 15ft at the most. I think it's XLS I just bought for the main sheet and it seems fine.
I sail in SF bay so it's all about strong winds and I'd like that line to not stretch, in turn keeping the draft forward, in the gusts.
Old 05-02-2011
Hudsonian is on a distinguished road
I'd check inside your boom. I have a four to one purchase in the boom of my 30 foot sloop.
Old 05-02-2011
Only 2 to one on mine, and that's done between the clew and the boom end, so no more than an extra couple of feet there.
Old 05-02-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
With that short run, your aren't going to get much stretch. I'd just go with a good quality double braid.
Old 05-02-2011
PalmettoSailor will become famous soon enough
How about Phd from Yale? I went with Salsa line for my out haul which is another line you might consider.
The outhaul is definitely an application for a low stretch line, especially for cruisers that wont be tweaking it all the time.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
Outhaul for Loose Foot Main Quickstep192 General Discussion (sailing related) 21 06-06-2011 12:07 PM
Loose Foot Main sail vs Foot Bolt Rope in boom Track chef2sail General Discussion (sailing related) 42 02-10-2011 08:37 PM
Main Outhaul Issue sailak General Discussion (sailing related) 5 05-08-2010 10:37 AM
Increasing purchase on cunningham and outhaul. zz4gta Gear & Maintenance 14 03-03-2009 10:09 AM
Main Cunningham Size/Purchase/Line max-on Gear & Maintenance 5 06-06-2008 11:11 AM
