05-04-2011
Engine cools hot water
I have a raw water cooled Volvo MD7A engine in my Islander 30 Bahama. I have a domestic hot water heater that runs on 110 volt shore power and is plumbed into the engine cooling water. The cooling water exits the thermostat housing, through a heat exchanger in the water heater and then out to the exhaust for exhaust cooling.
I usually heat the water in the heater before I leave the dock. However, when I run the engine, the engine cooling water cools the water in the heater. This happens because the engine runs cool and because there is a bypass line in the thermostat housing that is always keeping “cold” water running through the line.
I am considering inserting a bypass line with a 3 way valve that will allow me to bypass the heater. When the heater contains cool water and I’m running the engine hard for a while, it does warm the water a little – so I could redirect the flow through the heater for that case.
I’d be interested in hearing how others have addressed this same problem.
Thanks in advance.
Islander 30 - What I Do
