Shaft has no hole for Cotter Pin? - Page 2 - SailNet Community
post #11 of 17 Old 05-06-2011
I don't discuss my member
Fstbttms's Avatar
Originally Posted by rbrasi View Post
I recently removed the old Martec folding prop and bought a fixed one. When I slid it up to the taper, it had A) not enough threads for two nuts and B) no hole for a cotter.
Before I go and do something rash like drilling a hole, can someone explain why this is?
If the boat ever wore a Max Prop, it is possible that the shaft had to be shortened to allow the cone gear to seat properly. Regardless, as you undoubtably know by now, the Martec folder does not use or require a cotter pin through the shaft.
If you only have room for a single nut now, the proper remedy is to buy a crown nut and simply drill the shaft for a pin wherever it is convenient.
Fstbttms is offline
post #12 of 17 Old 05-06-2011 Thread Starter
rbrasi's Avatar
Excellent advice, people. Especially on the drilling part by Mr. Lucas. I was not aware of the drill features mentioned.
Anyway, I've decided to put the old Martec back on. If it ain't broke, don't break it. I wanted to go with a fixed prop, but it's not worth the trouble.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #13 of 17 Old 05-06-2011
overbored's Avatar
If you do drill, follow Gary's advice on the drill motor and I would add that the drill bit should be high speed steel type with a 118 degree split point. 135 degree will work but on harder material like stainless the flater the angle the better. drill bit coating is not really an issue as you will only be drilling one hole and on a 1/8" hole you will want 400 to 500 rpm for stainless. you could use a solid carbide bit but they are expensive and break easily when drilling by hand. these bits by Ryobi are the best for hand drilling stainless I have found
Ryobi 21 Piece Drill Bit Set - A10DB21 at The Home Depot
they very cheap ( $ 15 for the set ) and hold up as long a the best high speed bits you can buy. I own a machine and fab shop that specilizes in stainless steel and we buy these for the field crews. they are a good set to keep on the boat also hold up well on fiberglass
"GOLD RUSH" PRINDLE 16
overbored is offline
post #14 of 17 Old 05-06-2011
Newbie 'Wog
20 hp diesel on 30' 1968 Cal 2-30
Many application that use a second nut will not require a cotter pin - the second nut (aka "stop nut", "pal nut", "jam nut", "lock nut") performs the locking function of the cotter pin for a single nut.
"Seek to understand before you seek to be understood."
WDfrmTN is offline
post #15 of 17 Old 05-06-2011
Our prop shaft only has 1 nut and no cotter pin and when I spoke to my buddy who's a pro, he tells me its virtually impossible to have that nut to come undone.
booboonme is offline
post #16 of 17 Old 05-06-2011
JimsCAL's Avatar
Nothing wrong with the Martec prop. Does require a reconditioning every 5 years or so, but the reduced drag and no spinning prop when sailing is worth it. Make sure you use monel cotter pins when putting it back on. Martec cautions against using stainless to avoid electrolysis. If your blades are "floppy" or open more than 90 degrees, its time for a reconditioning.
JimsCAL is offline
post #17 of 17 Old 05-06-2011 Thread Starter
rbrasi's Avatar
I ordered the monel pins from Martec. They cost $5. My original plan was to go with the fixed prop to get more efficiency out of the diesel particularly in reverse. I bought a beautiful Acme three blade and was going to keep the Martec as a backup. Alas, the shaft is not as versatile, though, to be fair, it is perfect for the folding prop.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
Idea for turnbuckle cotter pins davidpm Gear & Maintenance 51 12-11-2009 06:54 PM
Cotter pin? harpguitar Gear & Maintenance 8 06-08-2009 04:33 AM
Cotter Pins ccriders Gear & Maintenance 9 06-04-2009 12:56 PM
Martec Prop Cotter Pins rperret Gear & Maintenance 13 04-06-2009 09:57 PM
Cotter Pin lsusailing Gear & Maintenance 22 09-06-2008 01:51 AM
