How do I remove paint on top of Awlgrip? - Page 3 - SailNet Community
post #21 of 21 Old 05-08-2011
I think I'd put some hardy tape around the names and numbers to limit the damage to the surrounding area as you try to sand the old off. You may need to replace it a time or two as you cannot help but abrade it along the way.
If you wet sand starting with say 220 or 320 and work your way up to 600 as the remaining paint thins out you may not have a big job of buffing it back somehow. But ghosting is going to be an issue, I suspect, esp with that colour. You may need to put another name in the same area to 'hide' it.
Faster is online now
how to remove enamel registration # on Awlgrip paint? PopeyeMike Gear & Maintenance 3 06-15-2010 07:22 PM
Paint or Awlgrip jkimberly Gear & Maintenance 7 09-16-2009 05:26 PM
AWLGRIP Paint /nonskid question mangomadness Gear & Maintenance 9 07-24-2008 10:15 AM
What is the best way to remove bottom paint??? Hargadoo Gear & Maintenance 19 10-25-2006 12:42 PM
New Awlgrip Paint Repair eyebbober Gear & Maintenance 1 10-02-2004 04:17 PM
