Old 05-06-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Tapered cone seacock fix
I recently pulled the cone out of a seacock, and found the tapered cone was cracked almost the entire circumference. Don't suppose there is a source for replacing just the cone?
Old 05-06-2011
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
Find a used one and lap it in with valve grinding paste?
But you could spend more on gas and take longer looking, finishing up with an old seacock.
Just buy new and fit.
Old 05-06-2011
Barquito's Avatar
Barquito
That's true. A new one shouldn't be too expensive. It is only 3/4".
Old 05-07-2011
Gladrags1's Avatar
Sailor
Gladrags1 is on a distinguished road
Is this a seacock made out of maleron and made by Forespar? If so, Forespar will replace internal parts. Mail your querie to them, provide model number, size and age. They replaced some parts for free for me on my 20+ year old boat. great service!
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Old 05-08-2011
centaursailor's Avatar
Senior in age only!!!
centaursailor is on a distinguished road
If no spares available, best choice, you can also get a local machine shop to make a new taper and lap that in, will save disturbing the main body and through hull fitting. Engineering colleges are usually looking for real projects for the students.
Safe sailing.
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
tapered plugs scosch Gear & Maintenance 18 02-20-2008 01:18 PM
Tapered battens ltdavis Cruising & Liveaboard Forum 1 02-01-2007 06:05 PM
