05-06-2011
If the engine is going to be sitting idle for more than a few months, I would drain the tank and refill with non-ethanol fuel. I've heard of some folks topping off their tanks with 100LL, which is available at most small general aviation airports.
The stuff is terrible... I'm not defending it. However, I've also heard from lots of folks who have just used fuel stabilizer during winter lay-up who have not had problems. In general, if the fuel starts to get shades of red, that means it's starting to separate and "stratify." If you see that at the end of the layup, drain the tank, clean it, clean your lines, carb, filters -- everything -- and use fresh fuel.
