Originally Posted by seayalatermoonglow
I have a wet suite but I think all I would need is a dry suite, the rest I have.
I hope this was a typo if not you need to ask some more questions.
1. A dry suit needs a hose from the second stage regulator. You need to check to see if the device you plan on buying supports using a dry suit.
2. Dry suits are much more expensive than wet suits, check the prices on-line.
3. Your introductory certification will not include dry suit certification. That is considered an advanced class.
4. If the water is cold but you don't expect to be deep or in it for too long a semi-dry suit may be what you are looking for.
The biggest differences in pressure are between 0 and 33 feet. You go from one atmosphere to two atmosphere's. This means the gas you are breathing is compressed double. If you go to 66 feet 3 atmosphere's it is compressed triple.
There are several things you can do to hurt yourself that the course will teach you.
1. If you breath compressed air at 33 feet and hold your breath and surface you will almost certainly cause damage as your lungs have to
2. If you spend enough time at depth and depending the person and the depth that depth can be a shallow as 30' and you surface too fast the nitrogen in your blood can bubble off and cause a serious medical condition sometimes hours after you surface.
3. You should know how to remove and replace your mask underwater.
4. You should know how to remove and replace your weights underwater.
In short you should know how to handle it if something goes wrong. What if you get tangled in mono-filament underwater? What if you stir up a lot of sediment and visibility goes to 0. What if your air is shut off.
The general idea with scuba people is to never dive alone. While finding a buddy to do a quick scrub of the bottom will probably not be doable, the first few times you are underwater having an instructor present is probably a good idea.
In short the disclaimer is not legal mumbo-jumbo. There are serious risks that a smart person would not necessarily figure out just with common sense.
