Painting an aluminum spar - Page 2 - SailNet Community
 7Likes
post #11 of 20 Old 05-09-2011
Tim R.'s Avatar
Her is my spar refinish from our previous boat. Rolled and tipped Interlux Perfection.
Mast Repaint
Click on each photo to get the full text.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #12 of 20 Old 05-09-2011
Midwest Puddle Pirate
US27inKS's Avatar
Tommays did exactly what I did to my mast, with excellent results for both of us. The only difference is that I sand blasted my mast instead of stripping and sanding. I got a very uniform surface, but it was a lot of work to clean all the sand out of the mast. I also used a flattening agent in my paint. I used a flattening agent on the deck paint to give it a semi gloss look and wanted the mast to match. This also allowed me to skip sanding the primer.
One thing I didn't see mentioned is all the rivets to reattach the hardware. I used 316 stainless rivets, which are very hard to pull in. You have to use a large two handed rivet gun, and when the rivet "pops" it will give you enough of a jolt that you'll be lucky to not chip your new paint job.
John USYacht 27 "Cora Lee"
US27inKS is offline
post #13 of 20 Old 05-10-2011
Tim R.'s Avatar
I used SS rivets on mine and placed a piece of thick leather around the fittings to avoid the inevitable chipping when the rivet gun pops. I simply pressed a 1/2" hole in the leather so the face of the rivet gun would fit through.
Tim R.
1997 Caliber 40LRC
Tim R. is offline
post #14 of 20 Old 06-10-2011
What happens if you skip the 353-wash step? I have the same products (primekote and perfection) but am having some difficulty tracking down the wash in the time that I need it. Are there any other alternatives?
Faster: You wiped it down with vinegar...like regular have-it-in-my-kitchen vinegar?
harraik is offline
post #15 of 20 Old 06-10-2011
Impressive finish Treilly!
harraik is offline
post #16 of 20 Old 06-11-2011
Originally Posted by harraik View Post
....Faster: You wiped it down with vinegar...like regular have-it-in-my-kitchen vinegar?
Yes it was.. this was recommended to us by a locally well regarded boat painter. Aside from two small (1" square) areas around the gooseneck that bubbled a bit, the mast turned out pretty good. Those patches were probably areas missed in the prep or wash.
Another advantage is avoiding the nasty fumes of the various washes.. but you need the masks and filters for the paint anyway.
Faster is online now
post #17 of 20 Old 06-11-2011
fryewe's Avatar
Jarcher,
Pilot Supplies, Avionics, and Homebuilt Aircraft Parts from Aircraft Spruce and Specialty Co. sells the materials needed for stopping corrosion and prepping aluminum for painting. Their materials are of the nature of those used to preserve aircraft in a salt water environment, such as on an aircraft carrier. Their website is useful.
When I repainted my mast and boom, I used their alumiprep #33 and alodine #1201, buying a quart of each, and had excess after prepping my 34 foot mast and 11 foot boom. Instructions for use come with the order. They are very easy to use.
I didn't take all the paint off my mast and boom. I removed fittings and sanded until I got all the loose paint and corrosion off. Paint that was well-adhered stayed on the mast. I painted both mast and boom with a brush and put on two coast of Interlux Brightsides. I had a couple of minor runs on the mast, but I thought it looked great for a thirty three year old boat.
It still looks pretty good after a year of use including stepping and unstepping the tabernacled mast myself using the boom as a lever, and hauling the boat on my trailer with the mast laid across padded pulpits and center support.
Cal28 and Rhapsody-NS27 like this.
fryewe is offline
post #18 of 20 Old 06-11-2011 Thread Starter
jarcher's Avatar
Thanks everyone, this is great info! Hopefully I'll get the spar this week and with some luck, it will be stepped by July 4th. So many tasks, so little time. My instruments are still not back after the bulked repairs, and I just learned my line clutches for the genoa halyards are slipping in all but the lightest air. Always a challenge!
I'll post pics!
Helios
Scampi 30 MK-IV
jarcher is offline
post #19 of 20 Old 06-12-2011
Catboat
Um...how about reevaluating the acquisition decision? You say it is much lighter than your original mast, and already has a splice?
Spyder is offline
post #20 of 20 Old 06-12-2011 Thread Starter
jarcher's Avatar
Well, its much lighter than the current mast, which is way oversize.
Helios
Scampi 30 MK-IV
jarcher is offline
Painting small aluminum parts cghubbell Gear & Maintenance 3 04-07-2010 10:52 AM
Aluminum painting issues. SiXeVeN Gear & Maintenance 7 09-01-2009 07:23 PM
Painting aluminum svindigo Gear & Maintenance 18 04-21-2009 03:19 PM
Glazing lexan and painting aluminum Alden68 Gear & Maintenance 6 04-02-2007 09:36 PM
painting anodized aluminum mroskothen Gear & Maintenance 1 08-13-2003 02:51 PM
