Old 05-08-2011
jarcher's Avatar
jarcher is on a distinguished road
Racor R12S or R12T ???
Hi All...
I have a Racor R12S filter in my diesel fuel system. The Engine is a 2 cyl Yanmar (I forget which model number). The Racor is installed between the tank and the engine and, as far as I know, there is no other filter in the system.
From reading product descriptions, I see that the R12S is a 2 micron filter, while the R12T is a 10 micron filter. This filter has a little plastic attatchment that catches water and allows it to be drained.
I am wondering, would it be better to use an R12T instead of an R12S given that this is the first (and I think only) filter in the fuel line?
Helios
Scampi 30 MK-IV
Old 05-08-2011
RichH's Avatar
RichH will become famous soon enough
There should be an engine mounted filter ... besides the Racor.
The typical Yanmar engine mounted filter is 15-17µM (rated). The proper Racor to precede this engine mounted 'guard' filter is a 10µM (R12T). If there is no engine mounted filter then use just the 10µM.
Tank ---> 10µM ----> (15-17µM 'guard' --->) engine.
Old 05-08-2011
Irrationally Exuberant
arf145 is on a distinguished road
2 micron is too small for the primary filter--and I'm fairly sure your Yanmar has a secondary. If your Yanmar is a 2GM20F, it is on the forward end of the engine on the heat exchanger. What I've heard is that having a 2 micron on the primary can make the lift pump work harder.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 05-09-2011
jarcher's Avatar
Thanks very much guys, I'll replace the filter tomorrow.
Helios
Scampi 30 MK-IV
Kudos to Racor bron Diesel Engine Forum 0 08-17-2010 09:01 PM
Racor Filter NautiG Gear & Maintenance 2 12-24-2007 02:12 PM
racor question rperret Gear & Maintenance 8 06-19-2007 01:18 PM
Racor With Too Much Water?? pma_foyl Gear & Maintenance 5 07-12-2004 01:52 PM
Racor Fuel Filter aphil138 Gear & Maintenance 2 03-15-2004 02:20 PM
