hard vang means no topping lift? - Page 2 - SailNet Community
post #11 of 15 Old 07-11-2003
Moderator
Jeff_H's Avatar
In someways not being able to use a vang as a preventer is a good thing. A preventer should be a little stretchy (in case you dip a boom or death roll) and should be releasable quickly and reliably from the cockpit and should allow the boom to move fully across the boat under control. When you use a boom vang as a preventer, there usually is too much friction for a quick and controlable release and rarely is there enough line to be able to allow the boom to fully cross the boat.
Respectfully,
Jeff_H is online now
post #12 of 15 Old 07-11-2003 Thread Starter
um.. I thought that a preventer was something to stop the main from Jibeing. (sp?) Am I wrong? if not, how on earth does a vang do that?
Thanks
-- James
jbarros is offline
post #13 of 15 Old 07-11-2003
Moderator
Jeff_H's Avatar
On a lot of boats, the lower block in the vang is attached to the mast with a snap shackle that can then be moved to the toerail or ringbolt near the rail to be used as a preventer. Its a bad idea but its done all of the time.
post #14 of 15 Old 07-11-2003
I know it''s a bad idea if it''s rough enough for the boom to dip into a wave....are there some other reasons I should know about?
Jim
joub is offline
post #15 of 15 Old 07-11-2003
Please disregard the above...for some reason I did''t see some of the dialog before I asked the question.
Jim
joub is offline
Topping Lift sehopkins Learning to Sail 16 05-04-2015 06:56 AM
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Topping lift PBzeer Seamanship & Navigation 11 02-19-2004 07:39 PM
rigid vang for small sloop or... Any excuse to upgrade. jbarros Gear & Maintenance 2 10-16-2003 02:01 PM
Boom Vang z1nonlyone Gear & Maintenance 5 08-21-2003 08:51 AM
