05-10-2011
Originally Posted by NoWet
Good Day.
[Hate to start a new thread, but can't seem to get below 35 PAGES of search results...a downfall of such a great forum.]
I want to put stainless steel eye strap on my boom (aluminum). Also want to put a cheek block on the aluminum mast. These will be hardware for a lazy jack system.
I'd rather use rivets than screws, but not sure if I should use stainless or aluminum rivets. I'd guess that stainless are stronger.
As to the title of this post, I'll be introducing dissimilar metals -- stainless and aluminum. So I know I need to use something like Tuf-Gel to help guard against galvanization. Correct so far?
My main question is, should I use aluminum rivets and put the Tuf-Gel between the base of the eye straps and spars, or use the stainless rivets and squeeze Tuf-Gel into the drilled holes (as well as between the eye strap base and spar).
Should I use Butyl tape between the stainless eye strap base and the spar? If I lay the tape over the drilled holes (hole to hole) that rivets will enter, I can then place the eye strap on the tape (which will separate the two dissimilar metals) and when I put the rivet in, won't it take a bit of the butyl tape into the drilled hole and thus protect the rivet from making contact with the aluminum spar?
Thanks.
I just installed a rigid boomvang, and used stainless rivets into the boom. I covered the end of the rivet with Lanocote before putting it in the hole, and also coated the bracket where it will be in contact with the boom.
If you look at the boom and the mast on my boat, there are many, many stainless fittings installed with stainless rivets. I assumed Bristol knew what they were doing and copied them with the boomvang.
I've no idea about the butyl tape - can anyone else chip in?
