Old 05-10-2011
cghubbell's Avatar
1977 CS27 ~ Ravat
cghubbell is on a distinguished road
Pedestal Refinishing
Greetings again,
While I have my pedestal off the boat, I was toying with the idea of scuffing it up with some 180 grit and hitting it with a can of spray paint in a white that's eyeballed close to the current color.
I know the original Edson pedestal is powder coated with unobtaniam. Mine doesn't look bad at a distance, but the finish is getting to be in rough shape. After Awl-Grip on the topsides it looks a little conspicious. Never should have made the rest of the boat look so darn good!
I don't recall banging too much on it, and I would think that a white-on-white scratch wouldn't show much anyway. I have seen the Edson document which recommends an expensive and labor intensive Interlux process. I'm sure that would look gorgeous, but not sure I want to put that much into it. Maybe?
Any reason why a can of premium Krylon or Rust-o-leum after a nice scuff and cleaning wouldn't make it look great and last for a long time? I hit my toe rails with flat black, and while I have scratched them in a few places they look unbelieveable.
For the record, this is a fresh-water only boat.
Thoughts appreciated as always.
Thanks,
Chris
CS27 #1254 ~ Ravat
Port of Rochester
Lake Ontario
Old 05-10-2011
Siamese is on a distinguished road
Do it. Worst case scenario, it doesn't look good in a couple years and then you splurge to have it blasted and powder coated.
Old 05-10-2011
tommays's Avatar
I did the boom and mast in the good stuff BUT was not gonna pop for a quart of black to do to small boom parts
The Black Rustoleum has done fine in saltwater
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Cetol refinishing mstern Gear & Maintenance 7 04-16-2008 02:00 PM
Wiring GPS: pedestal or pedestal guard? geary126 Gear & Maintenance 14 05-17-2007 02:43 PM
Refinishing brass twilk Gear & Maintenance 1 10-25-2003 02:08 PM
Refinishing Teak Dan Dickison Gear and Maintenance Articles 0 05-22-2001 08:00 PM
Refinishing Gelcoat Don Casey Gear and Maintenance Articles 0 04-08-2001 08:00 PM
