Hi all,
Sealants are often discussed here. I have two questions, and I don't think these have been discussed (or at least I couldn't find answers when searching). First the background...
I'm installing a Nicro Day/Night vent on the cabin top, which has some camber (within tolerances according to Nicro). The vent is for a composting head, and is stainless on top, but the base where it seals to the deck is plastic. It's going through a cored deck (yes I'm sealing the core with epoxy) with a stiff fiberglass headliner (see illustration below).
Question 1:
My first question is about what sealant to use with the plastic-based vent to the deck. The instructions from Nicro state that silicone should be used on a flat surface, but on a cambered surface (like ours) one should use 3M5200 or Sikaflex (they don't not specify which one), along with the rubber gasket they include. No way am I using 5200! I'd like to be able to remove the vent some day if needed.
Although I'm a big fan of butyl tape, this vent is only screwed into the deck (3 screws), not through-bolted. I'm wondering if this is one of those applications where we might want more adhesive properties than butyl tape can give, but still a good amount of flexibility due to the camber. Maybe Sikaflex 295UV (seems flexible and strong but not too strong)? Other?
Question 2:
My second question is about how to seal off the space between the deck and the liner. It's about 1" vertical space, and with the vent all assembled that space is not sealed off from air going to the vent. Since this is for a composting head, we need to make sure that air going to the vent only goes out of the boat. Any suggestions on what to seal it off with? I thought of window/door foam (it doesn't expand much and is soft, not hard), but I can't figure how to use it in a space with no "back". In other words, I could end up filling a LOT of headliner space with foam shooting out of can deep into the space. I only need to seal off right around the vent, not the entire headliner. Suggestions on what to use?
As always, thanks for the input!
-J
