Old 05-12-2011
MarkSF is on a distinguished road
Adding couple more layers of varnish
The exterior teak was done 3 years ago with 8 layers of Pettit 1015, and looks good still.
I'd like to add a couple more layers. To prepare the surface, can I just lightly sand? I'm worried about getting a good adherance without peeling.
Old 05-12-2011
treilley's Avatar
treilley is on a distinguished road
Read the can.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
Old 05-12-2011
MarkCK's Avatar
MarkCK is on a distinguished road
There is probably a better way. But yes, just lightly sand with a very fine grit sandpaper. Wipe the area thoroughly and apply another coat of varnish.
Old 05-12-2011
b40Ibis is on a distinguished road
yes. just sand with 320g and put another 2 coats on there. And lightly sand between coats. This is what I am doing right now... keep ahead of it.
Old 05-12-2011
badger hair china bristle brush applies the best finish. I used foam brushes and I think the ease of clean up does not out weigh the results w/ badger hair
Varnish stiffwind Gear & Maintenance 1 04-12-2011 11:20 PM
2, 3, 4 layers of packing in stuffing box? FishFinder Gear & Maintenance 16 05-18-2010 02:54 PM
How Do You Get Varnish Off lofty22810 Gear & Maintenance 6 12-13-2008 12:51 AM
update: moisture trapped between two gelcoat layers tappers Gear & Maintenance 1 01-12-2002 06:23 PM
moisture trapped between two gelcoat layers tappers Gear & Maintenance 10 01-04-2002 11:07 AM
