Old 05-15-2011
booboonme is on a distinguished road
We had that same problem and found an Orange residue removal product that was fairly good, but that was after trying acetone and everything else. Ultimately what happened was after the winter it sort of dried up and then came off pretty easily. It was an absolute bitch and we spent hours working on it, you have me condolences!
  #12
Old 05-15-2011
Adrift
XPatriot is on a distinguished road
Goof Off.
1977 Hunter 25
S/V 'Brily'
Sassafras River, MD
  #13
Old 05-15-2011
AlexHallMalta is on a distinguished road
Try WD40, before anything stronger. Its good for much cleaning.
  #14
Old 05-15-2011
JRA1968 is on a distinguished road
WD-30 should take care of your issue. Be a little patient as to let it work in some. WD has almost never failed me and is environmentally friendly. Cheers
  #15
Old 05-15-2011
dacap06 is on a distinguished road
Send a message via Yahoo to dacap06
I second WD40. It works well for just about any tape adhesive and many thing made from petroleum distillates. I recently used it to remove the tape residue from duct tape. It may require a little rubbing and several applications.
I have yet to harm paint with WD40 but I have never tried it with hull paint. You might want to try it first on an inconspicuous area, say, under the transom by the rudder.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
  #16
Old 05-16-2011
please keep in mind many of these things are really hard on gel coat such as goof off, it will probably just melt gel coat and most of all these products will destroy paint so like it says in the book of words...test a small area and proceed with caution! WD 40 sometimes works but wouldn't even faze the residue we had.
You may post attachments
You may edit your posts
How to remove butyl tape from a track? jarcher Gear & Maintenance 4 04-10-2010 12:00 AM
Another INTERPROTECT 2000 question sailordave Gear & Maintenance 4 04-20-2009 04:32 PM
Why is there white residue on my deck? saurav16 Gear & Maintenance 5 05-25-2008 07:07 PM
do i need to remove rudder to remove shaft 37cc jumpnkd Irwin 4 04-13-2008 10:48 AM
How to Remove nasty glue residue from headliner? gratefulsailor19 Gear & Maintenance 4 02-07-2007 12:26 PM
SEO by vBSEO 3.6.1
