05-13-2011
Here are Pettit's instructions for varnishing bare teak :
1. Sand the wood smooth with 120 grit production paper to open up the grain. Wipe the surface thoroughly with Pettit 120 Brushing Thinner in an effort to
aggressively remove as much oil as possible.
2. Apply a generous coat of Pettit 2018 Clear Sealer. After an overnight dry, lightly sand the surface with 220 grit sandpaper and wipe it clean with a rag
dampened with Pettit 120 Brushing Thinner.
3. Apply at least four coats of Z-Spar 1015 Captain's Varnish. Let each coat dry overnight, sand with 220 grit sandpaper, and clean off sanding residue with a
tack rag before applying the next coat. Sand the next to last coat with 400 grit production paper prior to applying the final coat.
