05-15-2011
At home, I glued it to the old on a large counter plus an island used for eating, projects , whatever, by an active cook and a growing family with 3 boys. Even glued over the vertical edge piece that covered the wood edge of counter. It stayed good for over 20 years until we went to stone. Jusy be sure to give old a good sanding, then spread marine grade contact cement on both top and new laminate after carefully shaping it for a perfect fit. Spread the cement, let dry, then cover that completely with brown paper like grocery bag paper, then lay new piece on top. You can move the new around until it is laying perfectly positioned, then hold is there while you pull the paper out. The glue doesn't stick to paper but once the new laminate touches the glue on the counter it locks right where it is so procede carefully.
Mike sullivan
1985 Marshall 22 catboat
