-   -   Deck Waste Caps (http://www.sailnet.com/forums/gear-maintenance/74473-deck-waste-caps.html)
Jolubrle 05-15-2011 05:49 PM
Deck Waste Caps
I just bought a 1978 Crown 34 and the first time pumping out the waste holding tank managed to drop the cap into the bottom of Puget Sound. The Perko caps that I have found don't seem to have the same thread pattern. Anyone know what type of cap may fit this older boat? Thanks in advance for any help.
Minnewaska 05-16-2011 06:43 AM
I'm assuming it isn't that unusual or the pump out guy wouldn't have had an adapter. Maybe they could tell you what the thread pattern was and search for one on the internet.
Another option is to swap out the deck fitting for something that takes a cap you can more easily locate. You may find a marina or two along the way that will help you drop that cap in the drink, so having a spare is helpful.
arf145 05-16-2011 10:13 AM
Hmmm, our marina's pump-out is just a tapered rubber nozzle you shove in the waste outlet--threads not important.
Jolubrle 05-21-2011 12:52 PM
I'm sorry maybe I didn't explain it well enough. The cap I need to replace is the one on the boat that seals up the hole you pump out of. It is a threaded cap that screws in to the fitting on the boat that closes the hole.
Minnewaska 05-21-2011 09:00 PM
Got it the first time. Ask the pump out guy about the adapter he used to pump you out, then look it up on the internet. Or change out the deck fitting (ie the part the cap screws in to) to something more common.
tap 05-22-2011 02:51 AM
Minnewaska, I don't think the pump out guy used any kind of adapter.
I think Perko has two metal deck fills. One is for hose and one for pipe, with the pipe one being slightly larger.
See these two fills:
Fisheries - Product Detail
Could be one is the one you want and the other isn't. Or maybe they just don't make your cap anymore? You might be able to find one at a consignment store like Second Wave. I managed to find an old Perko pull ring that was designed to fit into my anchor locker lid that way.
Or just get a new deck fill. Just the cap for the Perko pipe fill is $44, while you can get a 316 stainless Sea-Dog deck fill, with a cap, for $16 or $22 depending on if it's for pipe or hose. It's like $5 for a plastic fill.
centaursailor 05-22-2011 03:29 AM
You could also measure the thread form with a thread guage and the outside diameter with a micrometer or vernier. These are common tools in any engineering workshop.
Then either find a suitable cap or nut to blank off.
Safe sailing
SVAuspicious 05-22-2011 07:56 AM
Some pump-out hoses have a rubber conic section that gets pushed into the waste deck fitting. One holds it down to make a good seal.
Other pump-outs have a threaded adapter that is tightened into the deck fitting. The rest of the suction hose snaps onto the threaded adapter.
With respect to your cap, perhaps it is a metric cap? I know mine (Swedish boat) often create some confusion at places that use the threaded adapters. Since Crown's were made in Canada it is conceivable that it is a non-SAE (English) thread and diameter.
imagine2frolic 05-22-2011 08:02 AM
You can always stuff a piece of clay to mold to one half of the threads, so you can pull it out, and match it up..........i2f
JimsCAL 05-22-2011 08:08 AM
Here's some possibilities right here from the Sailnet store:
Sailing Hardware: Harken, Lewmar, Schaefer, Forespar. Marine electronics from Raymarine, Garmin, Furuno, more
A similiar search on your favorite marine store (Defender,
West Marine, etc.) will give other choices. Look for the one that matches your other fittings (water and fuel).
SEO by vBSEO 3.6.1
