Varnishing Teak Veneer - SailNet Community
Blogs
Old 07-11-2003
Stormer is on a distinguished road
Has anyone had experience varnishing 1/4" teak - faced plywood? How did you handle sanding/filling to get rid of the grain?
I''m concerned that if I sand I will go right through to the plywood. How has anyone else delt with this?
Thanks.
Old 07-11-2003
Jeff_H's Avatar
Super Moderator
I have usually lightly sanded with 220 grit, tacked down the plywood, wiped it off with alcohol to remove natural oils and then applied a first coat of 1/2 varnish, 1/4 penetrol and 1/4 terpentine. That will raise the grain slightly. Then I lightly sand with 220 again and use straight varnish. When I have a big sheet of plywood to do, I use a roller to apply the varnish and then quickly tip it off. If you have the luxury of being able to keep the plywood horizontal you can avoid runs and apply a bit more millage with each coat. I am a big fan of allowing each coat to thoroughly cure although I will often use a quick drying varnish to build up base coats. I typically do not try to get the varnish very level until the 5th or 6th coats and then once sanded level I typically apply a two or three topcoats.
The other thing that I have seen people doing lately but personally have not tried on anything this big, is to do a couple coats of epoxy for the first couple coats and then sand and put a couple coats of varnish over it. Prep is the same as for varnish. The idea sounds good and I tried it on some brackets that I made last year when I installed a new stove.
One last point about teak veneered plywood. There are several grades. For a few dollars more I would try get a ''deck grade'' which has a thicker face veneer.
Old 07-12-2003
paulk's Avatar
paulk is on a distinguished road
I tried the epoxy then varnish on a new section of floorboard on our boat last year. It seems to be holdng up well. It''s in the galley area, so sees a good deal of activity. On sanding, remember that they sand it before it leaves the factory, so it doesn''t need much, if any, more prior to appying a coating.
Advice refinishing teak and holly sole mcagney Gear & Maintenance 11 09-24-2009 08:03 AM
Teak or no teak... Keyne Boat Review and Purchase Forum 20 08-10-2006 07:08 PM
varnishing oiled teak? lhooks Gear & Maintenance 8 02-22-2006 09:40 AM
Diesel Stain in Teak Veneer vikinglady herSailNet 1 07-22-2001 10:35 PM
Varnishing Teak DICKWATERS Gear & Maintenance 0 06-09-2001 06:43 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
