05-16-2011
Installing a prop
OK, so my prop fell out, lost at sea. Fortunately the previous owner gave me a spare prop, presumably the original prop with the boat, since the lost one was a folding prop. I went diving under the boat and the spare prop fits perfectly on the shaft. But I can't figure out how to fix the prop on the shaft.
Here is what my situation is:
- The shaft has a conical shape the prop fits perfectly in it.
- 2 blade bronze prop
- The shaft has a groove, so does the prop. I am guessing I need some sort of pin in there to align the shaft with the prop so it does not spin.
- I am guessing I need some sort of nut to lock the prop in place.
So clearly fate has yet to give me a new lesson on how to fix my boat. Here are the questions I have:
1) Do I need to take the boat out of the water or is this something I can fix with scuba gear?
2) What is the pin that prevents the prop from spinning on the shaft called? Where do I get one?
3) Do I need one or two nuts to fix the prop in place? It seems some props have a conical nut, others have two nuts and others just have one.
Any advice would be much welcome. This is the first time something like this happens to me, I don't have a big budget, so I'd like to do as much as I can myself.
Also, I googled for tutorials, but could not find any. If you know of one, please post.
Thank you,
Kim
