Old 05-17-2011
lapworth is on a distinguished road
Flushing your outboard?
I have 6hp merc outboard and after a day or weakened of sailing I just pull it up and go home. Sometimes I have to un clog it and this time it was clogged pretty good. My engine specs tell me to run fresh water after every time out in muddy or salt water. Does anyone here flush there motor every time they go out?
Old 05-17-2011
AdamLein's Avatar
AdamLein will become famous soon enough
Used to, after the last time the cooling system clogged. Haven't this season, because I'm a bad bad person. Should really start again.
s/v Essorant
1972 Catalina 27
Old 05-17-2011
jrd22's Avatar
Courtney the Dancer
I flush it whenever I have access to fresh water but while we are cruising for the summer it may only get flushed once or twice. I always flush them if they are not going to be run for a long time (winter, etc).
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 05-18-2011
Originally Posted by jrd22 View Post
I I always flush them if they are not going to be run for a long time (winter, etc).
Yep! I didn't flush out after Dec.
Old 05-18-2011
sailjunkie's Avatar
Mirage 29
sailjunkie is on a distinguished road
We have a 4hp Yamaha that lives on a commercially built mounting bracket, in our carport shed, when we're not out sailing. I flush whenever we bring the engine home, using a screw-in attachment that fits to our garden hose.
I have to admit that I get a kick out of watching the reaction of our neighbours when I do this.
Mark
S/V Avatar
Mirage 29'
Port Moody, BC
It's not my fault they named a movie after our boat
Old 05-18-2011
Gecko36i is on a distinguished road
You should flush if you are not using everyday it will only increase life of engine. If leaving for a long period drain fuel from bowl and carby. Spray protective oil into cylinders by removing spark plugs. I did this to a 90hp Yamaha and stored for 7 years and she started first atempt.
Old 05-18-2011
Silvio's Avatar
Battered and Bruised
Silvio is on a distinguished road
Flush when fresh water is readily available, otherwise it waits. No real problems yet, who knows what the future holds though.
Old 05-19-2011
14432's Avatar
14432 is on a distinguished road
Love those Yamahas
Old 05-19-2011
donlofland is on a distinguished road
I'd like to flush my late 80's Merc 9.9, but there's really no way to do it while it's mounted on the boat-if I tip it out of the water to hook up the hose, I can't get to the starter cord.
Last winter I had the boat on the hard, so brought the motor home to do some service, and left it in the garage with the intent to run it every couple of weeks-but snow on the ground and the hose coiled up in the garage instead of on the spigot made that inconvenient, so it went a month or more without getting run, and then I had to dissassemble and clean the carbeurator to get it going again.
This winter it's been on the boat, run every 2-3 weeks, and so far doing fine.
FLushing an outboard RookieHunter Learning to Sail 19 08-09-2009 09:45 AM
Flushing a raw water diesel L124C Gear & Maintenance 3 05-14-2009 01:59 AM
Earmuff seal when flushing outboard AdamLein Gear & Maintenance 3 04-05-2009 10:32 PM
Flushing Scale MIKEMCKEE Gear & Maintenance 4 04-12-2008 10:57 AM
Flushing Atomic 4 Dao Newport 1 12-14-2006 05:13 PM
